YAMAHA MOTOR ACCGNRST50 REMOTE STARTER INTERFACE MODULE
Features- Allows you to start and stop your yamaha generator remotely
- Starting is fully automatic using the wireless remote start or stop switch on the easy-to-carry key fob transmitter
- Start kit automatically activates the choke when needed so you can even start a cold generator with ease
- Panel-mounted key switch can still be used to start the generator when desired
- Weight - 0.0800
- Used for - Start and stop yamaha generator ef3000iseb
- Includes power wiring harness - Yes
Price: 729.76
