THOR TH5000 KIT2 TH001 REMOTE WITH 10 FT. OF 3-0 CABLE WITH 400 AMPLIFIER FUSE
5000 Watt professional grade power inverter kit. Allows connection from power inverter to battery bank. Plug &Play deign. Best efficiency and highest safety level. Low maintenance Strong and compact. Thor power inverters have been designed to support professionals looking for superior performance in an affordable package. Pre-assembled the inverter kits allow for a quick easy and installation of the high power Thor inverters and require no special tools. It is imperative in any inverter permanent installation to use the appropriate material to get the best performance prevent overheating and avoid added maintenance costs or damages. Use of Thor kits is highly recommended for all mobile applications to ensure superior safety and efficiency.
Features- Full output power - 5000 watt &10000 watt peak modified sine wave power inverter. Low noise &self adjusting cooling fan. Ground fault sensing - designed to protect people against electric shock
- Overload protection - inverter will automatically shut down if load exceeds inverter rating
- Smart Surge Control Inverter will attempt to start loads above the continuous rating for up to 10 seconds.
- Voltage Protection Whenever the input exceeds 15 volts DC or is less than 10 volts the inverter will automatically shutdown
- Short Circuit Protection Automatically shuts down until short circuit is removed. Thermal Cutoff Automatically shuts down if internal temperature exceeds safe design parameters
Includes- TH5000-10000 Watt continuous Modified Sine Wave Inverter
- 10 ft. of 3-0 cable with 400 amplifier Fuse
- Six Lugs
- TH001 Remote
Price: 988.64
