MOTIVE GEAR M92-MGK112 RING AND PINION GEAR AND INSTALLATION KIT FOR DANA 30 AND DANA 44 - 4.10 RATIO
Want to get back the power and gas mileage that you lost from installing those big tires in your Jeep makes it easy to re-gear your 4 x 4 with their ring and pinion gear and installation kit combos. These complete kit combos include front and rear ring and pinion sets plus front and rear bearing kits giving you everything you need to re-gear the front and rear differentials in one package. The kits come in a wide range of ratios for most Dana applications. Their quality is the result of years of development outstanding design and state-of-the-art manufacturing methods to ensure a perfect fit for an easy install.
Features
Price: 1027.47
