MIDTRONICS MDX-700HD HEAVY DUTY ELECTRICAL SYSTEM ANALYZER BATTERY STARTER AND ALTERNATOR TESTING
Features- Help prevent expensive roadside breakdowns or towing and ensure your vehicles are available and operating efficiently. The MDX-700 Heavy Duty tester combines individual or pack battery tests with full system testing diagnostics including starter and alternator onto the back-lit easy to read screen. These all-in-one results can also be printed out on units equipped with the optional integrated printer.
- Specially designed for the HD/Commercial Fleet Market.
- Battery Pack Testing for effective preventative maintenance testing.
- Battery Routines for 1-6 batteries.
- Special commercial battery algorithms for Group 31 batteries 8D and 4D batteries.
- Multiple Vehicle applications.
- Large Back-lit screen and improved user interface.
- Integrated Printer option.
- 15' tester cable for efficient testing from the cab.
- New clamp designed specifically for HD and Commercial testing.
- Improved removable cable design.
- Item Weight - 8.0 lbs.
Price: 962.05
