LANZAR RBOPTI2601D OPTIDRIVE DIGITAL MONO BLOCK 2600 WATT HALF OHM STABLE POWER AMPLIFIER
The OPTI series of monoblock amplifiers pack a huge punch. These digital amps are equipped with single-channel class-D amplifiers for greater power efficiency meaning you’ll get a bigger sound with less power. The OPTI2000D pushes up to 2600 watts RMS power at 0.5 ohms. It’s equipped with several variable filters and boosting options including a low-pass filter subsonic filter bass boost and bass frequency. OPTI amps are bridgeable for increased power. Nickel plated screw terminals provide low-noise connections between the amplifier and your speakers. Remote subwoofer level control lets you easily adjust the bass. And this amp is equipped with thermal overload and short circuit protection so you know your equipment is safe and secure.
610 Watts RMS Power @ 4 ohm.
1070 Watts RMS Power @ 2 ohm.
1670 Watts RMS Power @ 1 ohm.
2600 Watts RMS Power @ 0.5 ohm.
THD 4ohm Power 0.5%.
0.5 ohm Stable.
Frequency Response: 10Hz-250Hz.
S/N Ratio (4 ohm ): 90dB.
Variable subsonic: 15Hz-45Hz.
Phase shift: 0~180 degrees.
Variable LPF: 50Hz~250Hz.
Variable Bass freq: 21Hz~80Hz.
Variable Bass Boost: 16dB.
Source Voltage: 9 - 18VDC.
Line In and Line Out.
Strap two amps together for twice the power.
Nickel-plated RCA connectors and Screw terminals.
Thermal Over load and Speaker short protection.
Double Side Epoxy PCB Circuit Board.
Power and Protection LED Indicators.
Remote subwoofer Level control.
Soft Turn-on/Turn-off.
Dimensions: 10.63"W x 2.12"H x 17.72"L.
Price: 502.34
