KISAE IC1220100 2000W SINEWAVE INVERTER WITH 100A BATTERY CHARGER
Features- Multi-stage battery chargers ensure that your batteries are harged the way battery manufacturers recommend.
- Small footprint extremely compact design.
- Ideal chargers for boaters and RV'ers.
- Can be set for gel flooded AGM and lithium batteries.
- Faster charge for your batteries.
- Three 12V models to hoose fom : 20A(<200 ab batteies) 40A (200-400Ah batteries) 60A(>400 Ah batteies).
- 24V model : 30A (>200 Ah batteies).
- Travel abroad and use anywhere(accept 90 - 285 VAC input).
- Optional remote allows you to view system information.
- Miro processor controlled multi-stage charging algorithms: bulk absorptionfloat settings for get flooded and AGM batteries.
- Battery equalization feature for flooded batteries.
- Priority bank charging ensures your main battery recharges first.
- Silent mode for quiet operation.
- Charge up to three battery banks.
- Item Weight - 5.1 lbs.
Price: 1529.93
