The new Optimate PRO 8 is a highly versatile 6/12V battery-care center for up to 8 batteries at a time. Compatible with all lead-acid models GEL MF-AGM or conventional the new Optimate PRO 8 can be used on starter batteries as well as on industrial motive or stationary-oriented types. Just connect up to 8 (even dissimilar) bat- teries and these will be individually taken through Optimates widely acclaimed multi-stage program - Desulfation (if necessary) constant current bulk charge verification final test & limitless maintenance. Countless connection variations are possible either enhancing charge current for larger batteries or handling series-connected blocks or both. Combinations up to 8A or 96V are possible. State-of-the-art diag- nostics charging testing and recovery of otherwise dead batteries all in a single device.
Features
