GO POWER GPC-75-MAX 75 AMP BATTERY CHARGER
The Go Power Battery Chargers are compact powerful battery chargers that offer fast accurate battery charging at a reasonable cost. Using state-of-the-art switch mode technology Go Power Battery Chargers are reliable compact and lightweight. All models feature switchable output modes one for float charging and one for rapid charging and a four-stage charger with an automatic “equalization” stage to periodically boost charge batteries. This is especially useful for batteries which often sit idle for long periods.
Features- 4 Stage Battery Charging
- Easy Installation
- Fuse Protection
- Thermostatically Controlled Fan
Applications Include- RV’s / Campers
- Long Haul Trucks
- Boats
- Mobile Offices
- Service Vehicles
- Scissor Lifts
Specification- Dc output Voltage (no Load) approx - 13.6V (Dc)
- Output Voltage tolerance (no Load) - + / - 0.7%
- Output amperage Max continuous - 55 amps
- Output Voltage (full Load) approx - >13.4V (Dc)
- Maximum power output continuous - 780 watts
- Input Voltage Range - 105-135ac
- Input Voltage frequency - 47-63
- Maximum ac current @ 108Vac - 12 amps
- Typical efficiency - >85%
- Max inrush current Single cycle - 40 amps
- Short circuit protection - Yes
- Overload protection - >100%
- Fan control - Proportional
- Thermal protection - Yes
- Working temperature Range - 0-45c°
- Dimension - 7.5 x 10.5 x 3.45 in.
- Item Weight - 5 lbs.
Price: 588.98
