ALL POWER SUPPLY MS4024 4000 WATT- 24V INVERTER - 105 AMP CHARGER
Inverter Specifications.
Input battery voltage range 18 - 34 VDC.
Nominal AC output voltage 120 VAC.
Output frequency and accuracy 60 Hz 0.04%.
Total Harmonic Distortion (THD) < 5%.
1 msec surge current (amps AC) 120.
100 msec surge current (amps AC) 72.
5 sec surge power (real watts) 5800.
30 sec surge power (real watts) 5400.
5 min surge power (real watts) 4900.
30 min surge power (real watts) 4500.
Continuous power output at 25° C 4000 VA.
Rated input battery current 204 ADC.
Inverter efficiency (peak_ 87%.
Transfer time 16 msecs.
Search mode (typical) 7 watts.
No load (120 VAC output typical) 25 watts.
Waveform Pure Sine Wave.
Charger Specifications.
Continuous output at 25° C 105 ADC.
Charger efficiency 85%.
Power factor > .95.
Input current at rated output (AC amps) 29.
General Features and Capabilities.
Transfer relay capability MS2000: 30 A single input MS2012 MS2812 MS4024: 2 legs at 30 A for 120 V/30 A or 240 V/60 A service.
Five stage charging capability Bulk Absorb Float Equalize (requires remote) and Battery Saver.
Battery temperature compensation Yes 15 ft Battery Temp Sensor standard.
Remote available (optional) Yes MM-RC or ME-RC.
Internal cooling 0 to 120 cfm variable speed drive using dual 92mm brushless DC fans.
Overcurrent protection Yes with two overlapping circuits.
Overtemperature protection Yes on transformer MOSFETS and battery.
Conformal coating on PCBs for corrosion protection Yes.
Powder coated chassis and top for corrosion protection Yes.
Stainless steel fasteners for corrosion protection Yes.
Dual AC branch rated output breakers Optional on the MS2000 and MS2012 - AC breakers in 15 or 20 amp ratings.
Physic
Price: 2723.76
