ALL POWER SUPPLY MM612 600 WATT 12V MODIFIED SINE WAVE INVERTER NO BATTERY CHARGER
A Cost Effective Inverter from Magnum Energy.
Introducing the MM Series Inverter from Magnum Energy - a new modified sine wave inverter providing a cost effective solution for those with smaller power needs in mobile applications. Versatile easy-to-use and lightweight the MM Series provides a reliable base for your energy system.
The modern hourglass case paired with the die cast aluminum base combines form with function creating an attractive unit that uses its baseas a heat sink for superior high temperature operation.
Features:
The standard 7 Amp transfer relay will pass AC power through the inverter when using shore or generator power.
The MM Series is fan cooled enabling the unit to work well in confined spaces. If the inverter does exceed its temperature limits it will automatically shut down and then restart when it cools down.
If your battery voltage reaches below 10 VDC or above 15.5 VDC the MM Series will automatically shut down.
The MM Series will automatically shut down if its output wattage is exceeded or it detects a short in the wiring saving the unit from costly damage.
The MM Series comes with an on/off front mounted switch with an easy-to-read LED indicator.
Every model comes with built in input and output circuit breakers for ease of installation.
The MM Series is backed by a two-year (24-month) parts and labor warranty.
In the box:
MM612 Inverter
Installation hardware
Owners manual
Price: 570.96
