AIMS POWER PWRINV5K24012W 5000 WATT MODIFIED SINE POWER INVERTER 240VAC
This Aims 5000 watt 240 VAC 60HZ power inverter is designed to handle a well pump or water pump in your off-grid cabin or ranch. It has two 240Vac outlets and an AC direct connect terminal block. The direct connect terminal block can provide the full 5000 watts of power out of a single connection.
Features- 5000W max continuous power.
- Modified sine wave.
- Red LED indicates over heat.
- Red LED indicates over load.
- Dual ac receptacle universal.
- Volt and amp meter.
- On/off switch.
- Over Temperature protection.
- Over Load protection.
- Single cooling fan operation.
- Internally fuse protected.
- AC output short circuit protection.
- Aluminum case for optimal cooling.
- Pre-slotted mounting plate.
Specification- Continuous output power: 5000 Watts.
- Surge power capability (peak power): 10000 Watts.
- DC input / operating voltage: 10 to 15 Volts.
- Output voltage: 240 Volts ac.
- Output frequency: 60 Hz +/-.5 Hz.
- Battery low voltage alarm: 10.5 +/- 0.5 Volts.
- Battery low voltage shutdown: 10.0 +/- 0.5 Volts.
- No load minimum operating temperature: 30-150 degrees F.
- Full load maximum operating temperature: 150 +/- 5 degrees F (automatic shutdown).
- Low voltage and over voltage alarm and protection.
- AC output Socket Type: dual 240.
- Low input voltage shutdown: 10V.
- Dimension - 22.5 x 7 x 8.26 in.
- Item Weight - 20 lbs.
Price: 712.72
