AIMS POWER PWRINV500048W 5000 WATT POWER INVERTER 48 VOLT INPUT
The AIMS 5000 watt 48 volt inverter for consumers looking for a reliable 48 volt inverter that offers 5000 watts of continuous power. This modified sine wave model is designed to perform in even the most rugged off-grid applications including jobs in the field marine recreation camping trips and any other scenario
Features- 5000 Watt max continuous power.
- 48 Volt Power Inverter.
- Modified sine wave.
- Volt meter on front panel to monitor your battery voltage.
- Amp meter on front panel to monitor your current use (rate at which battery is drained).
- AC Direct Connect Terminal.
- Over Temperature LED indicator.
- Over Load LED indicator.
- Quadruple ac receptacle that can be used with any separate splitter to provide even more outlets.
- On/off switch.
- Over Temperature protection.
- Over Load protection Single cooling fan operation thermally controlled Internally fuse protected AC output short circuit protection.
- Auto reset on most fault conditions.
- Aluminum case for optimal cooling.
- Pre-wired for remote on/off switch.
- Pre-slotted mounting plate.
Specification- Continuous output power: 5000 Watts.
- Surge power capability (peak power): 10000 Watts.
- DC input / operating voltage: 39 to 64 Volts.
- Output voltage: 120 Volts ac +/- 10%.
- Output wave form: modified sine wave with phase correction.
- Output frequency: 60 Hz +/- 1 Hz.
- Battery low voltage alarm: 40 +/- 0.5 Volts.
- Battery low voltage shutdown: 38 +/- 0.5 Volts.
- No load current: < 0.2 Amps.
- Full load efficiency: 90%.
- 1/3 load efficiency: 95%.
- No load minimum operating temperature: -15 degrees Celsius.
- Full load maximum operating t
Price: 713.70
