AIMS POWER PWRINV12KW24V 12000 WATT POWER INVERTER 24 VDC
This 12000 Watt Modified Sine Inverter is the most powerful unit available from AIMS and is the best value for performance in the market. This product is your best choice for a powerful efficient and reliable off-grid portable or emergency backup power source.
Features- 12000W max continuous power.
- Modified sine wave with Pulse Width Modulation technology (soft start).
- Volt meter on front panel to monitor your battery voltage.
- Amp meter on front panel to monitor your current use (rate at which battery is drained).
- Over Temperature LED indicator.
- Over Load LED indicator.
- AC direct connect terminal block.
- On/off switch.
- Over Temperature protection.
- Over Load protection.
- Dual cooling fans thermally controlled.
- Internally fuse protected.
- AC output short circuit protection.
- Auto reset on most fault conditions.
- Aluminum case for optimal cooling.
- Pre-wired for remote on/off switch.
- Pre-slotted mounting plate.
Specification- Continuous output power: 12000 Watts.
- Surge power capability (peak power): 24000 Watts.
- DC input / operating voltage: 20 to 32 Volts.
- Output voltage: 120 Volts ac +/- 10%.
- Output wave form: modified sine wave with phase correction.
- Output frequency: 60 Hz +/- 1 Hz.
- Battery low voltage alarm: 21.0 +/- 0.5 Volts.
- Battery low voltage shutdown: 20 +/- 0.5 Volts.
- No load current: < 0.6 DC amps.
- Full load efficiency: 90%.
- 1/3 load efficiency: 95%.
- No load minimum operating temperature: -15 degrees Celsius.
- Full load maximum operating temperature: 60 +/- 5 degrees Celsius (automatic shutdown).
- AC output Soc
Price: 2383.84
