AIMS POWER PWRINV10KW12V 10000 WATT POWER INVERTER
This AIMS 12 volt 10000 Watt DC to AC inverter is the best in its class on the market. This inverter can handle nearly any application with its 10000 watt continuous capacity and 20000 watt surge capability.
This new 10000 watt 12 volt inverter model has all the capabilities of AIMS Power’s new the 8000 watt 12 volt inverter but with a higher wattage capacity. This can come in handy if planning to power multiple appliances at once or a piece of equipment that demands a high wattage capacity such as an air conditioner or air compressor. These items use what’s called “locked rotor startup” or “locked rotor amperage” (LRA) which generates a surge that only a very powerful inverter can handle. This AIMS Power DC to AC inverter can get the job done because it handles 20000 watts of surge for 40 milliseconds.
Features- 10000W max continuous power.
- Modified sine wave with Pulse Width Modulation technology (soft start).
- Volt meter on front panel to monitor your battery voltage.
- Amp meter on front panel to monitor your current use (rate at which battery is drained).
- Over Temperature LED indicator.
- Over Load LED indicator.
- AC direct connect terminal block.
- On/off switch.
- Over Temperature protection.
- Over Load protection.
- Dual cooling fans thermally controlled.
- Internally fuse protected.
- AC output short circuit protection.
- Auto reset on most fault conditions.
- Aluminum case for optimal cooling.
- Pre-wired for remote on/off switch.
- Pre-slotted mounting plate.
Specification- Surge power capability (peak power): 20000 Watts.
- DC input / operating voltage: 10 to 15 Volts.
- Output voltage: 120 Volts ac +/- 10%.
- Output wave form: modified sine wa
Price: 1872.92
