AIMS POWER PWRIG300012120S 3000 WATT PURE SINE POWER INVERTER 12V
3000 Watt Pure Sine Power Inverter. This new and improved unit is capable of producing 3000 watts of pure sine wave power with higher quality and efficiency and can maintain normal output even as your batteries approach lower voltage. Pure sine power is ideal for running computers printers cordless drill battery chargers variable speed motors and drills and much more. This 3000 watt model also has a direct connect AC terminal block output which can be used to harness the full power of the inverter through a single output. For convenience there is also a dual outlet GFCI plug on the front of the inverter for quick connection of appliances under 1500 watts.
Features- 3000 Watt continuous power.
- 6000 Watt surge.
- 12 Volt DC input.
- Pure Sine Wave.
- 60hz or 50hz switch.
- Highly efficient - improved output at low voltage.
- 1 - GFCI Dual Outlet.
- Direct connect AC Terminal Block.
- External Digital display that shows battery voltage included.
- Connector and cable for remote on/off switch.
- Isolated ground &neutral (bondable).
- Short circuit protection (GFCI and AC Breaker).
- On/off switch.
- 5 Function Protection LED indicator.
- AC Breaker.
- Dual cooling fans thermally controlled.
Specification- Continuous output power: 3000 Watts.
- Surge power capability (peak power): 6000 Watts.
- DC input / operating voltage: 10.5-16 Volts.
- Output voltage: 120 Volts AC.
- Output voltage regulation: +/- 3%.
- Output wave form: pure sine wave.
- Output frequency: 50/60 Hz.
- Battery low voltage alarm: 10.5 +/- 0.5 Volts.
- Battery low voltage shutdown: 10.0 v +/- 0.5 Volts.
- No load power consumption: fan off <0.9 DC amps or fan on <1.37 DC
Price: 1421.09
