AIMS POWER PWRIG200012120S 2000 WATT PURE SINE POWER INVERTER 12V
2000 Watt Pure Sine Inverter. AIMS Power new 2000 Watt Pure Sine Power Inverter which has been completely overhauled and now boasts a dual GFCI outlet and is FCC certified. This product also includes a thermally controlled fan allowing for increased efficiency and less noise. It will continue to put out stable pure sine power and maintain output voltage even as you battery bank voltage decreases. High output performance is achieved through a DSP (Digital Signal Process) drive. This inverter will be ideal for running nonlinear loads. Pure sine power is also preferred for LaserJet printers sensitive electronics computer servers microwaves and cordless drill battery chargers.
Features- 2000 Watt continuous power.
- 4000 Watt surge.
- 12 Volt DC input.
- Pure Sine Wave.
- 60hz or 50hz switch.
- Highly efficient - improved output at low voltage.
- 1 - GFCI Dual Outlet.
- External Digital display that shows battery voltage included.
- Connector and cable for remote on/off switch.
- Isolated ground &neutral (bondable).
- Short circuit protection (GFCI and AC Breaker).
- On/off switch.
- 5 Function Protection LED indicator.
- AC Breaker.
- Dual cooling fans thermally controlled.
Specification- Continuous output power: 2000 Watts.
- Surge power capability (peak power): 4000 Watts.
- DC input / operating voltage: 10.5-16 Volts.
- Output voltage: 120 Volts ac.
- Output voltage regulation: +/- 3%.
- Output wave form: pure sine wave.
- Output frequency: 50/60 Hz.
- Battery low voltage alarm: 10.5 +/- 0.5 Volts.
- Battery low voltage shutdown: 10.0 v +/- 0.5 Volts.
- No load power consumption: fan off <0.70 DC amps or fan on <1.05 DC amps.
- F
Price: 781.47
