AIMS POWER PWRI8K22050 8000 WATT 220 VAC-50 HZ EUROPEAN AND AFRICAN POWER INVERTER
The 8Kw modified sine power inverter has a 12 volt input and a 220 volt 50hz output. This power inverter good for use in most European and African countries the unit has a direct connect AC terminal for larger loads and universal plugs to accept almost any type of male connector.
Features- 8000W max continuous power.
- Modified sine wave.
- Volt meter on front panel to monitor your battery voltage.
- Amp meter on front panel to monitor your current use (rate at which battery is drained).
- AC Direct Connect Terminal.
- Over Temperature LED indicator.
- Over Load LED indicator.
- 3 universal ac receptacles.
- On/off switch.
- Over Temperature protection.
- Over Load protection.
- Single cooling fan operation thermally controlled.
- Internally fuse protected.
- Auto reset on most fault conditions.
- Aluminum case for optimal cooling.
- Pre-wired for remote on/off switch.
Specifications- Continuous output power: 8000 Watts.
- Surge power capability (peak power): 16000 Watts.
- DC input / operating voltage: 10 to 16 Volts.
- Output voltage: 220 Volts ac.
- Output wave form: modified sine wave with phase correction.
- Output frequency: 50 Hz +/- 1 Hz.
- Battery low voltage alarm: 10.5 +/- 0.5 Volts.
- Battery low voltage shutdown: 10.0 +/- 0.5 Volts.
- No load current: < 0.6 Amps.
- Full load efficiency: 90%.
- 1/3 load efficiency: 95%.
- No load minimum operating temperature: -15 degrees Celsius.
- Full load maximum operating temperature: 55 +/- 5 degrees Celsius (automatic shutdown).
- AC output Socket Type: dual universal Type.
- High input voltage protection: 15V-17V.
- Low input voltage shutdown: 10V.
Price: 2119.10
