AIMS POWER PICOGLF30W24V120V 3000 WATT 24 VOLT PURE SINE INVERTER CHARGER
Features- 3000 watt low frequency inverter
- 9000 watt surge for 20 seconds -3x surge capability
- Battery Priority Selector
- Terminal Block
- GFCI
- Marine Coated and Protected
- Multi Stage Smart charger 40 Amp
- remote panel available
- auto gen start
- auto frequency
- 10msec typical transfer time
- optional 25W power save mode
- 7 battery type settings for charger
Specification- Continuous Output Power - 3000 Watts
- Surge Rating - 9000 Watts (20 Seconds)
- Output Waveform - Pure Sine/Same as input (Bypass Mode)
- Nominal Efficiency - >88% (Peak)
- Line Mode Efficiency - >95%
- Output Frequency - 50Hz +/- 0.3Hz / 60Hz +/- 0.3Hz
- Typical Transfer Time - 10ms (Max)
- THD -< 10% DC
- Nominal Input Voltage - 24.0Vdc
- Minimum Start Voltage - 20.0Vdc
- Low Battery Alarm - 21.0Vdc-22.0Vdc
- Low battery Trip - 20.0Vdc-21.0Vdc
- High Voltage Alarm - 32.0Vdc
- Low battery Voltage Restart - 31.0Vdc
- Idle Consumption -<10 amps AC
- Power Saver Mode Idle Consumption -<1 amps AC
- Output voltage - Depends on battery Type
- Charger Rate 40A
- Dimension - 23.54 x 8.59 x 7.05 in.
Price: 1011.15
