AIMS POWER PICOGLF20W24V120V 2000 WATT LOW FREQUENCY INVERTER CHARGER 24 VOLT
The 2000 watt low frequency model to consumers looking for a powerful and highly efficient inverter with built-in charger for off-grid applications ranging from marine recreation to in-the-field operations and everything in between.
Features- 2000 watt low frequency inverter.
- 6000 watt surge for 20 seconds 300% surge capability.
- Battery Priority Selector.
- Terminal Block.
- Marine Coated and Protected.
- Multi Stage Smart charger 30 Amp.
- Remote panel available.
- Auto frequency.
- 10msec typical transfer time.
- Optional 25W power save mode.
- 7 battery type settings for charger.
SpecificationsInverter Output- Continuous Output Power: 2000 Watts.
- Surge Rating: 6000 Watts (20 Seconds).
- Output Waveform: Pure Sine/Same as input (Bypass Mode).
- Nominal Efficiency: >88% (Peak).
- Line Mode Efficiency: >95%.
- Output Frequency: 50Hz +/- 0.3Hz / 60Hz +/- 0.3Hz.
- Typical Transfer Time: 10ms (Max).
- THD: < 10% DC.
Inverter Input- Nominal Input Voltage: 24.0Vdc.
- Minimum Start Voltage: 20.0Vdc.
- Low Battery Alarm: 21.0Vdc-22.0Vdc.
- Low battery Trip: 20.0Vdc-21.0Vdc.
- High Voltage Alarm: 32.0Vdc.
- Low battery Voltage Restart: 31.0Vdc.
- Idle Consumption: <2.5 Amps DCC.
- Power Saver Mode Idle Consumption: <1 amps AC.
Charger Specifications- Output voltage: Depends on battery Type.
- Charger Rate: 30A.
- Over Charge Protection Shutdown 31.4V.
- Selectable Charge setting based on battery type.
- Adjustable charge current off-20%-100%.
- Four Stage Smart Charger.
Transfer Switch Specifications- 30 amp
Price: 838.47
