AIMS POWER PICOGLF20W12V120V 2000 WATT PURE SINE INVERTER CHARGER LOW FREQUENCY 12V
The 2000 watt 12 volt low frequency AIMS Power inverter charger transforms DC (direct current) power stored by batteries into AC (alternating current) electricity that can be used to run most all tools and appliances. This inverter also has a built in AC-to-DC battery converter charger which allows users to recharge their battery bank from an AC source such as a fuel-powered generator shore power or a regular outlet at home.
Features- 2000 watt low frequency inverter.
- 6000 watt surge for 20 seconds 300% surge capability.
- Battery Priority Selector.
- Terminal Block.
- Marine Coated and Protected.
- Multi Stage Smart charger 40 Amp.
- remote panel available.
- auto frequency.
- 10msec typical transfer time.
- optional 25W power save mode.
- 7 battery type settings for charger.
SpecificationsInverter Output - Continuous Output Power: 2000 Watts.
- Surge Rating: 6000 Watts (20 Seconds).
- Output Waveform: Pure Sine/Same as input (Bypass Mode).
- Nominal Efficiency: >88% (Peak).
- Line Mode Efficiency: >95%.
- Output Frequency: 50Hz +/- 0.3Hz / 60Hz +/- 0.3Hz.
- Typical Transfer Time: 10ms (Max).
- THD: < 10% DC.
Inverter Input - Nominal Input Voltage: 12.0Vdc.
- Minimum Start Voltage: 10.0Vdc.
- Low Battery Alarm: 10.5Vdc-11.0Vdc.
- Low battery Trip: 10.0Vdc-10.5Vdc.
- High Voltage Alarm: 16.0Vdc.
- Low battery Voltage Restart: 15.5Vdc.
- Idle Consumption: <0.5 amps AC.
- Power Saver Mode Idle Consumption: <1 amps AC.
Charger Specifications- Output voltage: Depends on battery Type.
- Charger Rate: 40A.
- Over Charge Protec
Price: 764.40
