AIMS POWER PICOGLF15W12V120VR 1500W PURE SINE INVERTER CHARGER 12 V 120 VAC
Features- Battery Priority Selector
- Terminal Block
- Marine Coated and Protected
- Multi Stage Smart charger
- Auto gen start
- Auto frequency
- 10 m sec typical transfer time
- Optional 25W power save mode
- 7 battery type settings for charger
Specifications- Inverter Output Power: 1500 Watts
- Inverter Surge Rating:4500 Watts (20 Seconds)
- Inverter Output Waveform: Pure Sine/Same as input (Bypass Mode)
- Inverter Output Voltage: 100-110-120Vac
- Inverter Nominal Efficiency: >88% (Peak)
- Inverter Line Mode Efficiency: >95%
- Inverter Output Frequency: 50Hz +/- 0.3Hz / 60Hz +/- 0.3Hz
- Inverter Typical Transfer Time: 10ms (Max)
- Inverter THD:< 10% DC
- Nominal Input Voltage: 12.0Vdc
- Minimum Start Voltage: 10.0Vdc
- Low Battery Alarm: 10.5Vdc-11.0Vdc
- Low battery Trip: 10.0Vdc-10.5Vdc
- High Voltage Alarm: 16.0Vdc
- Low battery Voltage Restart: 15.5Vdc
- Idle Consumption: 4 amps DC
- Power Saver Mode Idle Consumption: <1.7 amps DC
- Dimension: 7.05" H x 8.59" W x 2.54" L
Price: 687.15
