AIMS POWER PICOGLF10W12V120V 1000 WATT PURE SINE INVERTER CHARGER - 12 VOLT
The AIMS Power 1000 Watt Pure Sine Low Frequency Inverter with built-in battery charger. This inverter charger is perfect for small-sized industrial applications that depend upon power being available even under heavy load. This heavy-duty inverter charger is ready to go wherever you need it to: campsites tailgating parties or just at home. Use this product to power your essential household appliances during a power outage emergency. This inverter is also great in a smaller RV or boat.
Features- 1000 watt low frequency inverter.
- 3000 watt surge for 20 seconds 300% surge capability.
- Battery Priority Selector.
- Terminal Block.
- GFCI outlet.
- Marine Coated and Protected.
- Multi Stage Smart charger 20 Amp.
- remote panel available.
- auto frequency.
- 10msec typical transfer time.
- optional 25W power save mode.
- 7 battery type settings for charger.
SpecificationInverter Output- Continuous Output Power: 1000 Watts.
- Surge Rating: 3000 Watts (20 Seconds).
- Output Waveform: Pure Sine/Same as input (Bypass Mode).
- Nominal Efficiency: >88% (Peak).
- Line Mode Efficiency: >95%.
- Output Frequency: 50Hz +/- 0.3Hz / 60Hz +/- 0.3Hz.
- Typical Transfer Time: 10ms (Max).
- THD: < 10% DC.
Inverter Input- Nominal Input Voltage: 12.0Vdc.
- Minimum Start Voltage: 10.0Vdc.
- Low Battery Alarm: 10.5Vdc-11.0Vdc.
- Low battery Trip: 10.0Vdc-10.5Vdc.
- High Voltage Alarm: 16.0Vdc.
- Low battery Voltage Restart: 15.5Vdc.
- Idle Consumption: <0.5 amps AC.
- Power Saver Mode Idle Consumption: <1 amps AC.
Charger Specifications- Output voltage: Depends on battery Type.
Price: 606.99
