AIMS POWER PICOGLF10KW48V240VS 10000 WATT INVERTER CHARGER 48 VOLT SPLIT PHASE 120-240 VAC
The most common use for this inverter is emergency backup power. The auto-generator start port is also a great feature for emergency backup power as it will automatically kick on your generator when it senses your battery bank getting low.
Features- 10000 watt low frequency inverter 110/220Vac Split Phase.
- 30000 watt surge for 20 seconds -3x surge capability.
- Battery Priority Selector.
- Terminal Block.
- Marine Coated and Protected.
- Multi Stage Smart charger 80 Amp.
- Remote panel available.
- Auto gen start.
- 10msec typical transfer time.
- Optional 25W power save mode.
- 8 battery charger settings.
SpecificationsInverter Output- Continuous Output Power: 10000 Watts.
- Surge Rating: 30000 Watts (20 Seconds).
- Output Waveform: Pure Sine/Same as input (Bypass Mode).
- 100-110-120Vac / 220-230-240Vac.
- Nominal Efficiency: >88% (Peak).
- Line Mode Efficiency: >95%.
- Output Frequency: 50Hz +/- 0.3Hz / 60Hz +/- 0.3Hz.
- Typical Transfer Time: 10ms (Max).
- THD: < 10% DC.
Inverter input- Nominal Input Voltage: 48.0Vdc.
- Low Battery Alarm: 42.0Vdc-44.0Vdc.
- Low battery Trip: 40.0Vdc-42.0Vdc.
- High Voltage Alarm: 64.0Vdc.
- Low battery Voltage Restart: 62.0Vdc.
- Idle Consumption: 3.125 amps DC.
- Power Saver Mode Idle Consumption: <0.73 amps DC.
Charger Specifications- Output voltage: Depends on battery Type.
- Charger Rate: 100A.
- Dimension - 23.3 x 7.9 x 16.3 in.
- Item Weight - 145.5 lbs.
Price: 3308.51
